소개
Documentation of disassembly of the entire phone.
  1. Start with gathering tools needed
    • Start with gathering tools needed
  2. Start with the back of the phone (the battery and cover has already been taken out.)
    • Start with the back of the phone (the battery and cover has already been taken out.)
  3. Place finger to take out the sim card. Then take out sim card. Place finger to take out the sim card. Then take out sim card.
    • Place finger to take out the sim card. Then take out sim card.
  4. Locate Screws
    • Locate Screws
  5. Unscrew the six screws. Unscrew the six screws.
    • Unscrew the six screws.
  6. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  7. With tweezers, pry around the sides to expose the circuitry.
    • With tweezers, pry around the sides to expose the circuitry.
  8. Remove the back part of the phone to expose the layers inside.
    • Remove the back part of the phone to expose the layers inside.
  9. Remove small parts from the sides. Remove small parts from the sides.
    • Remove small parts from the sides.
  10. Remove the layer connected with the keypad.
    • Remove the layer connected with the keypad.
  11. Release the keypad from the phone frame.
    • Release the keypad from the phone frame.
  12. With a prying tool, start opening the front face of the phone. With a prying tool, start opening the front face of the phone.
    • With a prying tool, start opening the front face of the phone.
  13. Remove the front cover, exposing the layers inside.
    • Remove the front cover, exposing the layers inside.
  14. Pry open the glued layer.
    • Pry open the glued layer.
  15. Remove all loose part, and should result in the components shown in the picture.
    • Remove all loose part, and should result in the components shown in the picture.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Anthony Aquino
회원 가입일: 2014년 04월 10일
155 평판
안내서 1개 작성함
University of Maryland, Team 1-6, Calloway Spring 2014 University of Maryland, Team 1-6, Calloway Spring 2014 회원
UMD-CALLOWAY-S14S1G6
1 회원
안내서 1개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 633
