주요 콘텐츠로 건너뛰기
Disassembling Lawn and Garden Bosch UniversalGardenTidy 3000 switch
  1. Disassembling Lawn and Garden Bosch UniversalGardenTidy 3000 switch, Switch stops turning on: 1 단계, 이미지 3개 중 1개 Disassembling Lawn and Garden Bosch UniversalGardenTidy 3000 switch, Switch stops turning on: 1 단계, 이미지 3개 중 2개 Disassembling Lawn and Garden Bosch UniversalGardenTidy 3000 switch, Switch stops turning on: 1 단계, 이미지 3개 중 3개
    • If you have this item and the turn switch resists turning on, this is because there is too much friction where the turn switch rubs the safety control micro-switch. You need to detach all the fittings to be left with the base, then remove the 11 screws (all the same size) keep them safe.
  2. Disassembling Lawn and Garden Bosch UniversalGardenTidy 3000 switch: 2 단계, 이미지 1개 중 1개
    • Once you have separated the two halves, you will be able to see that the knob on the switch has a cam that, when you turn it, depresses the micro-switch. In this photo the bottom on the micro-switch is red since I have already put red grease on it to reduce the friction.
  3. Disassembling Lawn and Garden Bosch UniversalGardenTidy 3000 switch: 3 단계, 이미지 1개 중 1개
    • This is the micro-switch from side on. You can see the red grease that I have put on it.
결론
작성자
2다른 기여자 명과 함께
Andy Pleming
회원 가입일: 04/05/23
169 평판
안내서 2개를 작성함
1가이드 댓글
Very helpful for fixing the stuck power knob.
I just fixed mine this way and it works like a charm. It only took a few minutes and cost nothing.
Jean Sébastien Franco - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 11
전체 시간: 38
