주요 콘텐츠로 건너뛰기
Disassembling Macintosh IIsi Floppy Drive
필요한 것
  1. Disassembling Macintosh IIsi Floppy Drive, Top Case: 1 단계, 이미지 2개 중 1개 Disassembling Macintosh IIsi Floppy Drive, Top Case: 1 단계, 이미지 2개 중 2개
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Disassembling Macintosh IIsi Floppy Drive: 2 단계, 이미지 3개 중 1개 Disassembling Macintosh IIsi Floppy Drive: 2 단계, 이미지 3개 중 2개 Disassembling Macintosh IIsi Floppy Drive: 2 단계, 이미지 3개 중 3개
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: 3 단계, 이미지 3개 중 1개 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: 3 단계, 이미지 3개 중 2개 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: 3 단계, 이미지 3개 중 3개
    • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
    • Push these two tabs out, and lift the drive up.
  4. Disassembling Macintosh IIsi Floppy Drive: 4 단계, 이미지 3개 중 1개 Disassembling Macintosh IIsi Floppy Drive: 4 단계, 이미지 3개 중 2개 Disassembling Macintosh IIsi Floppy Drive: 4 단계, 이미지 3개 중 3개
    • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
    • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
    • This drive was manufactured by Sony in 1990.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Chris Green
회원 가입일: 10/11/09
37,656 평판
안내서 49개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,697개를 작성함
댓글 한 개
Hi there, I have IIsi Mac but the driver couldn’t read all the floppy dsks!
note: it was stored for more than 7 years.
Q. How can I clean it and what is the suitable cleaning items you recommend?
thanks.
Abdulaziz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 2,815
