주요 콘텐츠로 건너뛰기
Disassembling Macintosh IIsi Power Supply
필요한 것
  1. Disassembling Macintosh IIsi Power Supply, Top Case: 1 단계, 이미지 2개 중 1개 Disassembling Macintosh IIsi Power Supply, Top Case: 1 단계, 이미지 2개 중 2개
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Disassembling Macintosh IIsi Power Supply: 2 단계, 이미지 3개 중 1개 Disassembling Macintosh IIsi Power Supply: 2 단계, 이미지 3개 중 2개 Disassembling Macintosh IIsi Power Supply: 2 단계, 이미지 3개 중 3개
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Disassembling Macintosh IIsi Power Supply, Floppy Drive: 3 단계, 이미지 3개 중 1개 Disassembling Macintosh IIsi Power Supply, Floppy Drive: 3 단계, 이미지 3개 중 2개 Disassembling Macintosh IIsi Power Supply, Floppy Drive: 3 단계, 이미지 3개 중 3개
    • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
    • Push these two tabs out, and lift the drive up.
  4. Disassembling Macintosh IIsi Power Supply: 4 단계, 이미지 3개 중 1개 Disassembling Macintosh IIsi Power Supply: 4 단계, 이미지 3개 중 2개 Disassembling Macintosh IIsi Power Supply: 4 단계, 이미지 3개 중 3개
    • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
    • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
    • This drive was manufactured by Sony in 1990.
  5. Disassembling Macintosh IIsi Power Supply, System Fan: 5 단계, 이미지 1개 중 1개
    • The fan recieves power from two contacts on the logic board and has no connector.
  6. Disassembling Macintosh IIsi Power Supply: 6 단계, 이미지 3개 중 1개 Disassembling Macintosh IIsi Power Supply: 6 단계, 이미지 3개 중 2개 Disassembling Macintosh IIsi Power Supply: 6 단계, 이미지 3개 중 3개
    • In all of the years that I have worked on this machine, I have found no good way to remove the fan.
    • The best way to start, is to push in here on the side of the fan.
    • Being careful not to exert too much force, try to push in, and wiggle the fan outward as such. (2nd Photo)
    • You can now lift the fan all the way out, and remove it.
    • The Fan Power Contacts on the Logic Board:
  7. Disassembling Macintosh IIsi Power Supply, Power Supply: 7 단계, 이미지 2개 중 1개 Disassembling Macintosh IIsi Power Supply, Power Supply: 7 단계, 이미지 2개 중 2개
    • To remove the power supply, squeeze these two tabs and lift the front up.
    • On the back of the power supply, there is a tab that also must be pressed to remove the power supply fully. You can then lift it out all the way. A firm tug may be necessary to seperate the power connector.
  8. Disassembling Macintosh IIsi Power Supply: 8 단계, 이미지 2개 중 1개 Disassembling Macintosh IIsi Power Supply: 8 단계, 이미지 2개 중 2개
    • Information on the power supply:
    • It was made by Sony in 1990, and uses a 10-Pin power connector.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Chris Green
회원 가입일: 10/11/09
37,656 평판
안내서 49개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,697개를 작성함
댓글 한 개
I was looking for the schematic for the power supply APS-06 pictured here. The information above would be a little helpful if one was really unaware of anything electromechanical,… otherwise, it’s all pretty obvious I think.
nikitesla - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 3,670
