주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Disassembling Marshall MS-2 Micro Amp Case Disassembly
필요한 것
  1. Disassembling Marshall MS-2 Micro Amp Case Disassembly, Case: 1 단계, 이미지 1/1
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Disassembling Marshall MS-2 Micro Amp Case Disassembly: 2 단계, 이미지 1/3 Disassembling Marshall MS-2 Micro Amp Case Disassembly: 2 단계, 이미지 2/3 Disassembling Marshall MS-2 Micro Amp Case Disassembly: 2 단계, 이미지 3/3
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Disassembling Marshall MS-2 Micro Amp Case Disassembly: 3 단계, 이미지 1/2 Disassembling Marshall MS-2 Micro Amp Case Disassembly: 3 단계, 이미지 2/2
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Disassembling Marshall MS-2 Micro Amp Case Disassembly: 4 단계, 이미지 1/1
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
MacKinley
회원 가입일: 10/22/13
811 평판
안내서 5개 작성하였습니다
University of Maryland, Team 1-1, Shastany Fall 2013 University of Maryland, Team 1-1, Shastany Fall 2013 회원
UMD-SHASTANY-F13S1G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 22
전체 시간: 2,060
