주요 콘텐츠로 건너뛰기
Disassembling Marshall MS-2 Partner Circuit Board
필요한 것
  1. Disassembling Marshall MS-2 Partner Circuit Board, Disassembling Marshall MS-2 Micro Amp Case Disassembly: 1 단계, 이미지 1개 중 1개
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Disassembling Marshall MS-2 Partner Circuit Board: 2 단계, 이미지 3개 중 1개 Disassembling Marshall MS-2 Partner Circuit Board: 2 단계, 이미지 3개 중 2개 Disassembling Marshall MS-2 Partner Circuit Board: 2 단계, 이미지 3개 중 3개
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Disassembling Marshall MS-2 Partner Circuit Board: 3 단계, 이미지 2개 중 1개 Disassembling Marshall MS-2 Partner Circuit Board: 3 단계, 이미지 2개 중 2개
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Disassembling Marshall MS-2 Partner Circuit Board: 4 단계, 이미지 1개 중 1개
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
  5. Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: 5 단계, 이미지 2개 중 1개 Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: 5 단계, 이미지 2개 중 2개
    • Use a 9/16" socket to remove the nut around the headphone jack. Be careful to not lose the washer.
  6. Disassembling Marshall MS-2 Partner Circuit Board: 6 단계, 이미지 1개 중 1개
    • Remove the 7/16" phillips head screw.
  7. Disassembling Marshall MS-2 Partner Circuit Board: 7 단계, 이미지 1개 중 1개
    • Grab the headphone jack from inside the case and pull it toward the speaker until you can fully remove it from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
MacKinley
회원 가입일: 10/22/13
816 평판
안내서 5개를 작성함
1가이드 댓글
There Is a toroidal transformer inside ?
Jack redmond - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 8
전체 시간: 2,037
