주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Mercedes W123 Door Panel
필요한 것
  1. Disassembling Mercedes W123 Door Panel, Door Panel: 1 단계, 이미지 1개 중 1개
    • Begin by removing the door lock knob. It unscrews counter-clockwise.
  2. Disassembling Mercedes W123 Door Panel: 2 단계, 이미지 1개 중 1개
    • Remove the two screws that attach the chrome trim around the door latch. The chrome trim will come loose afterwards. Set aside.
    • Note: the screws shown are not original. Phillips head screws are the original equipment. These are 2.5mm allen head screws.
  3. Disassembling Mercedes W123 Door Panel: 3 단계, 이미지 1개 중 1개
    • Use a flat blade screwdriver to gently pry out the black plastic cover behind the door pull.
  4. Disassembling Mercedes W123 Door Panel: 4 단계, 이미지 3개 중 1개 Disassembling Mercedes W123 Door Panel: 4 단계, 이미지 3개 중 2개 Disassembling Mercedes W123 Door Panel: 4 단계, 이미지 3개 중 3개
    • Remove the screw that holds the chrome plate behind the door pull.
    • Once again, the 2.5mm allen screw shown is not original. This will normally be a Phillips screw.
    • On the driver's side door, with no upper section of the arm on the door panel, the chrome panel behind the door pull can simply be removed and set aside at this point.
  5. Disassembling Mercedes W123 Door Panel: 5 단계, 이미지 2개 중 1개 Disassembling Mercedes W123 Door Panel: 5 단계, 이미지 2개 중 2개
    • On the other three doors, the chrome panel is a part of the upper arm on the door panel. Pull the chrome panel out from behind the door pull. You will need to pull the door pull away from the door to get the chrome panel around it. It will move down the arm on the door panel.
  6. Disassembling Mercedes W123 Door Panel: 6 단계, 이미지 1개 중 1개
    • Remove the large Phillips head screw at the very top of the arm on the panel.
    • This step does not apply to the driver's door.
  7. Disassembling Mercedes W123 Door Panel: 7 단계, 이미지 1개 중 1개
    • Under the arms on all four doors, there are two large Phillips screws. They are hidden out of sight up in holes like the one pictured. Making sure to properly seat the screwdriver in the head, as to not strip the screw, loosen these screws.
    • There is no need to remove the screws from the holes in the arm; in fact, doing so will make it more difficult to re-install them. Just loosen them enough to remove the arms from the panels.
  8. Disassembling Mercedes W123 Door Panel: 8 단계, 이미지 3개 중 1개 Disassembling Mercedes W123 Door Panel: 8 단계, 이미지 3개 중 2개 Disassembling Mercedes W123 Door Panel: 8 단계, 이미지 3개 중 3개
    • For doors with manual windows, you will need to remove the crank before removing the panel.
    • Use a finger to push the tab that holds the trim piece to the crank out until it clears the crank.
    • Pull trim toward the knob on the crank to release the trim.
    • The trim piece will release from the peg at the base of the crank. The crank will now slide off.
    • When reassembling the manual window crank, make sure the tapered end of the washer is facing away from the door.
    • The tapered washer is sometimes missing. It is used to protect the panel from wear.
  9. Disassembling Mercedes W123 Door Panel: 9 단계, 이미지 2개 중 1개 Disassembling Mercedes W123 Door Panel: 9 단계, 이미지 2개 중 2개
    • Using a wide pry tool, like this trim removal tool, go around the edge of the panel between it and the metal part of the door. You will find it held in place by plastic clips. Gently pry each clip out all the way around.
    • On an older car like the W123, there will likely be some broken clips. Some times, panels are being held in place by only two or three clips.
    • Be aware that even though there should be no screws holding the panel to the door at this point, you will want to carefully check that someone didn't use a screw in the past to make up for broken clips. If you try and pull it off without removing the screw, you could damage your panel.
  10. Disassembling Mercedes W123 Door Panel: 10 단계, 이미지 1개 중 1개
    • On the rear doors, you will need to unplug the window switch from the plug and wire harness in the door before finally removing the panel.
  11. Disassembling Mercedes W123 Door Panel: 11 단계, 이미지 1개 중 1개
    • Remove the panel by pulling up on it. Do not pull straight out on the panel, or it may bend. This cannot be repaired. Pulling up on the panel before pulling out on it will also help ensure that you do not damage the plastic clips on the back of the map pocket on the door panel (only applies to front panels; rear panel shown in this picture).
  12. Disassembling Mercedes W123 Door Panel: 12 단계, 이미지 3개 중 1개 Disassembling Mercedes W123 Door Panel: 12 단계, 이미지 3개 중 2개 Disassembling Mercedes W123 Door Panel: 12 단계, 이미지 3개 중 3개
    • Pictured is the back of your door panel once removed. Notice the white plastic clips around the edge. Notice that many are missing. There should be several more on this door. Also, notice that some are broken.
    • Once the panel is removed, there should be a plastic vapor barrier between the panel and the door shell. This will need to be removed. If removed gently, it may be able to be reused. Otherwise, replace it with any thick plastic and 3M Spray Adhesive or contact cement. (Not pictured)
  13. Disassembling Mercedes W123 Door Panel: 13 단계, 이미지 2개 중 1개 Disassembling Mercedes W123 Door Panel: 13 단계, 이미지 2개 중 2개
    • This is a list of the major components within the door (front passenger side shown):
    • Window regulator (note, the rear window regulators are designed differently and are not immediately visible)
    • Door lock vacuum actuator, early style (does not apply to driver's door, which is equipped with the master vacuum switch instead, see attached picture). On later W123's, the actuators are in similar locations but look different.
    • Door pull
    • Door latch and lock mechanisms
    • Master vacuum switch (driver's door). Note that on later models the master switch will be oriented vertically instead of horizontally.
결론
다른 42명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nicolas Siemsen
회원 가입일: 12/06/13
40,383 평판
안내서 79개를 작성함
Master Techs Master Techs 회원
Community
332 회원들
안내서 1,473개를 작성함
3가이드 댓글
W114 is similar, except clips are metal. On the coupe, there is also a small screw holding in the lock lever chrome surround (there is no lock stem type knob in the coupe).
David Iwanicki - 답글
Nicolas, thanks for your  instructions, your clear color coded photos!!!! Thanks to you, I fixed my vacuum issues and now doors lock, engine shuts off and it shifts better!!   Bob Neimeyer
Bob - 답글
Schönen guten Tag!
Ich habe Probleme mit der Zentralverriegelung meines DB W1123, 230 CE, Bj. 1982. Beide Türen. Kofferklappe Tankverschluss keine Funktion, Motor lief nach Kaltstart nicht richtig rund. Hinter Motor 3 Ventile, sind o.k, am unteren Ventil (wohl Ersatz für Zweierverteiler) 1 Anschluss gelb mit grauem Streifen am Ventilanschluss war wohl nicht mehr dicht. Tank unter der Hutablage oben im Kofferraum i.O.. Der 2. Schlauch gelb. Mit Pumpe (gelb mit grau und nur gelb) Unterdruckbehälter und System abgepumpt. Dann Kofferklappe, Tankverschlussdeckel, Beifahrertür getestet, nur Beifahrertür keine Reaktion! Türverkleidung abbauen, soweit kein Problem, alle Klammern o.k. Am Bereich der Türhalterung kann man die Verkleidung nicht lösen, so fest wie angeschraubt, aber keine Schraube in Sicht. Welches Problem/Lösung gibt es hier? Außerdem ist Tür an der Scheibenkurbel auch fest. Wie Verkleidung nun zu entnehmen?
Gruß Reinhard 0173 5803960
A
Reinhard Heepe - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 40
지난 30일: 182
전체 시간: 39,612
