주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Mercedes W123 Kick Panel
필요한 것
  1. Disassembling Mercedes W123 Kick Panel, Kick Panel: 1 단계, 이미지 1개 중 1개
    • Begin by gently prying out the covers for the screws on the upper edge of the kick panel.
  2. Disassembling Mercedes W123 Kick Panel: 2 단계, 이미지 1개 중 1개
    • Then remove these screws.
  3. Disassembling Mercedes W123 Kick Panel: 3 단계, 이미지 2개 중 1개 Disassembling Mercedes W123 Kick Panel: 3 단계, 이미지 2개 중 2개
    • Then remove any metal screws, and any plastic trim screws, at the sides of the kick panel below the dash.
  4. Disassembling Mercedes W123 Kick Panel: 4 단계, 이미지 2개 중 1개 Disassembling Mercedes W123 Kick Panel: 4 단계, 이미지 2개 중 2개
    • Now lower the panel down and rest if on the floor.
    • It can be removed full for further ease of access, depending on the job at hand.
  5. Disassembling Mercedes W123 Kick Panel: 5 단계, 이미지 3개 중 1개 Disassembling Mercedes W123 Kick Panel: 5 단계, 이미지 3개 중 2개 Disassembling Mercedes W123 Kick Panel: 5 단계, 이미지 3개 중 3개
    • Now you'll want to identify some of the components you are looking at so you can begin working on the one that is having issues.
    • Here are some of the ones you may find. This car is a 1985 300D; if you have an older model the items are likely a bit different.
    • Heater blower motor
    • Over-voltage protection relay
    • Air-conditioning expansion valve
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Nicolas Siemsen
회원 가입일: 12/06/13
40,296 평판
안내서 79개를 작성함
Master Techs Master Techs 회원
Community
331 회원들
안내서 1,458개를 작성함
1가이드 댓글
Dear Nicolas.I have one 123 300D. 1983. This days i have the follow problem.When i turn on the switch the engine heater light just lights with low brightness and the same time the diesel level goes to full.as i turn on the engine the temperature starts going up also and in few minutes time goes until full.if it is night and i turn on the head lights on high beam the engine heat light lights with the high beam light also.After 15-20 minutes time when i driving the car everything return on normal.I check the engine heaters and are ok.my battery is new.Please help me were to check and loose this problem.
Best Regards
Pavlos
melaspavlos - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 80
전체 시간: 15,264
