주요 콘텐츠로 건너뛰기
Disassembling Mercedes W123 Kick Panel
필요한 것
  1. Disassembling Mercedes W123 Kick Panel, Kick Panel: 1 단계, 이미지 1/1
    • Begin by gently prying out the covers for the screws on the upper edge of the kick panel.
  2. Disassembling Mercedes W123 Kick Panel: 2 단계, 이미지 1/1
    • Then remove these screws.
  3. Disassembling Mercedes W123 Kick Panel: 3 단계, 이미지 1/2 Disassembling Mercedes W123 Kick Panel: 3 단계, 이미지 2/2
    • Then remove any metal screws, and any plastic trim screws, at the sides of the kick panel below the dash.
  4. Disassembling Mercedes W123 Kick Panel: 4 단계, 이미지 1/2 Disassembling Mercedes W123 Kick Panel: 4 단계, 이미지 2/2
    • Now lower the panel down and rest if on the floor.
    • It can be removed full for further ease of access, depending on the job at hand.
  5. Disassembling Mercedes W123 Kick Panel: 5 단계, 이미지 1/3 Disassembling Mercedes W123 Kick Panel: 5 단계, 이미지 2/3 Disassembling Mercedes W123 Kick Panel: 5 단계, 이미지 3/3
    • Now you'll want to identify some of the components you are looking at so you can begin working on the one that is having issues.
    • Here are some of the ones you may find. This car is a 1985 300D; if you have an older model the items are likely a bit different.
    • Heater blower motor
    • Over-voltage protection relay
    • Air-conditioning expansion valve
결론
다른 11명이 해당 안내서를 완성하였습니다.
Nicolas Siemsen
회원 가입일: 12/06/13
39,040 평판
안내서 79개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 한 개
Dear Nicolas.I have one 123 300D. 1983. This days i have the follow problem.When i turn on the switch the engine heater light just lights with low brightness and the same time the diesel level goes to full.as i turn on the engine the temperature starts going up also and in few minutes time goes until full.if it is night and i turn on the head lights on high beam the engine heat light lights with the high beam light also.After 15-20 minutes time when i driving the car everything return on normal.I check the engine heaters and are ok.my battery is new.Please help me were to check and loose this problem.
Best Regards
Pavlos
melaspavlos - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 15
30일 전: 64
전체 시간: 13,411
