소개
With this guide you can take your MM-4 from one solid brick of a speaker to four parts and a bunch of screws. This is useful if you are replacing a bad driver, or if the connector becomes damaged and you need to replace it.
  1. Turn the speaker face down, so the connector side is up. Remove the four #2 Philips screws on the back plate.
    • Turn the speaker face down, so the connector side is up.
    • Remove the four #2 Philips screws on the back plate.
  2. Remove the foam insert to expose the two spade connectors.
    • Remove the foam insert to expose the two spade connectors.
    • Carefully separate the connectors
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Turn the speaker so the grill side is up. Remove the four screws on the grill.  I had to use a t-10 Torx bit to remove them.
    • Turn the speaker so the grill side is up.
    • Remove the four screws on the grill. I had to use a t-10 Torx bit to remove them.
    • The grill is not glued on, but may require a bit of prying to remove.
  5. Remove the four silver bolts holding the speaker in place.  These bolts also have threads inset for the grill screws to fit into. This is a pretty quick and easy teardown, not too many parts in this one.  The meyer speaker's part number is ST-164.  It's a 16 Ohm driver.
    • Remove the four silver bolts holding the speaker in place. These bolts also have threads inset for the grill screws to fit into.
    • This is a pretty quick and easy teardown, not too many parts in this one. The meyer speaker's part number is ST-164. It's a 16 Ohm driver.
결론
다른 2명이 해당 안내서를 완성하였습니다.
RoggeSound
회원 가입일: 2010년 06월 05일
2,107 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 19
전체 시간: 5,798
