소개
The speaker is attached to the circuit board with two wires and is glued onto the front case. After the speaker is removed the new speaker will need to be re-glued and re-soldered into place.
필요한 것
First, apply pressure with your thumb on the top of the battery cover.
Next, pull down on the cover until it begins to slide.
Remove the circuit board from the front part of the radio case.
Clip the red and black connecting wires at the base closest to the circuit bored in the spots denoted by the two red circles.
다른 3명이 해당 안내서를 완성하였습니다.
