주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Motorola Cliq Rear Casing
필요한 것
  1. Disassembling Motorola Cliq Rear Casing, Battery: 1 단계, 이미지 2개 중 1개 Disassembling Motorola Cliq Rear Casing, Battery: 1 단계, 이미지 2개 중 2개
    • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
  2. Disassembling Motorola Cliq Rear Casing: 2 단계, 이미지 2개 중 1개 Disassembling Motorola Cliq Rear Casing: 2 단계, 이미지 2개 중 2개
    • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
    • The pull tab may be tucked under the battery.
  3. Disassembling Motorola Cliq Rear Casing, Rear Casing: 3 단계, 이미지 3개 중 1개 Disassembling Motorola Cliq Rear Casing, Rear Casing: 3 단계, 이미지 3개 중 2개 Disassembling Motorola Cliq Rear Casing, Rear Casing: 3 단계, 이미지 3개 중 3개
    • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
    • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
  4. Disassembling Motorola Cliq Rear Casing: 4 단계, 이미지 1개 중 1개
    • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
  5. Disassembling Motorola Cliq Rear Casing: 5 단계, 이미지 3개 중 1개 Disassembling Motorola Cliq Rear Casing: 5 단계, 이미지 3개 중 2개 Disassembling Motorola Cliq Rear Casing: 5 단계, 이미지 3개 중 3개
    • Turn the phone over and slide out the keyboard.
    • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
    • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
    • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
  6. Disassembling Motorola Cliq Rear Casing: 6 단계, 이미지 1개 중 1개
    • Carefully separate the back casing from the rest of the phone.
  7. Disassembling Motorola Cliq Rear Casing: 7 단계, 이미지 2개 중 1개 Disassembling Motorola Cliq Rear Casing: 7 단계, 이미지 2개 중 2개
    • Gently pry ZIF connector upwards using the flat end of a spudger tool.
    • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
    • You may need adhesive to keep your power cable in place when reassembling your phone.
  8. Disassembling Motorola Cliq Rear Casing: 8 단계, 이미지 3개 중 1개 Disassembling Motorola Cliq Rear Casing: 8 단계, 이미지 3개 중 2개 Disassembling Motorola Cliq Rear Casing: 8 단계, 이미지 3개 중 3개
    • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
    • The rear casing and the rest of the phone should now be completely separated.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Tony Tran
회원 가입일: 04/14/13
69 평판
안내서 8개를 작성함
Cal Poly, Team 10-42, Amido Spring 2013 Cal Poly, Team 10-42, Amido Spring 2013 회원
CPSU-AMIDO-S13S10G42
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 28
전체 시간: 716
