주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Motorola Defy XT
필요한 것
  1. Disassembling Motorola Defy XT, Disassembling Motorola Defy XT: 1 단계, 이미지 1개 중 1개
    • Switch off the mobile.
    댓글 쓰기
  2. Disassembling Motorola Defy XT: 2 단계, 이미지 1개 중 1개
    • Unlock the back case before open.
    댓글 쓰기
  3. Disassembling Motorola Defy XT: 3 단계, 이미지 1개 중 1개
    • Remove the battery
    • Remove the memory card
    • Remove the Sim card
    댓글 쓰기
  4. Disassembling Motorola Defy XT: 4 단계, 이미지 2개 중 1개 Disassembling Motorola Defy XT: 4 단계, 이미지 2개 중 2개
    • Remove 6 screws
    • Tear off a part of label
    • Release the usb cover
    댓글 쓰기
  5. Disassembling Motorola Defy XT: 5 단계, 이미지 1개 중 1개
    • Open the green case part by yours fingernail from left side to the right side with the usb socket
    • Be care of your labels
    • If you want to repair the SIM card slot legs, be sure no short circuits in 6 legs.
    댓글 쓰기
  6. Disassembling Motorola Defy XT: 6 단계, 이미지 2개 중 1개 Disassembling Motorola Defy XT: 6 단계, 이미지 2개 중 2개
    • To release the PCB for cleaning the Display the the touch screen, remove 2 PARTS by fingernail.
    • 1. Touchscreen adapter
    • 2. Sticker between the touchscreen PCB & mobile PCB
    • Remove the mobile PCB much careful form top right. Be care the touchscreen circuits.
    댓글 쓰기
  7. Disassembling Motorola Defy XT: 7 단계, 이미지 3개 중 1개 Disassembling Motorola Defy XT: 7 단계, 이미지 3개 중 2개 Disassembling Motorola Defy XT: 7 단계, 이미지 3개 중 3개
    • You can use a cloth, USB vacuum cleaner (be careful of the components in the green case), and adhesive tape to remove all the dust.
    • That finger pin is left by the Motorola Support Center in Hong Kong!!
    • You can also clean the camera lens on PCB
    댓글 쓰기
  8. Disassembling Motorola Defy XT: 8 단계, 이미지 1개 중 1개
    • Remember to put all parts back and insert the touchscreen plugs slightly.
    • Put the green case back, make sure all locks is conneted
    댓글 쓰기
  9. Disassembling Motorola Defy XT: 9 단계, 이미지 1개 중 1개
    • You can test the mobile before screw.
    • After insert the memory card, SIM card and battery, switch on the phone
    • Test call in and call out, also check the speaker
    • Open the map Apps to test Wifi and GPS
    • Bluetooth file transfer
    • Camera test and save in sd card
    • Check the sd card files
    • Try to connect with PC
    댓글 쓰기
  10. Disassembling Motorola Defy XT: 10 단계, 이미지 3개 중 1개 Disassembling Motorola Defy XT: 10 단계, 이미지 3개 중 2개 Disassembling Motorola Defy XT: 10 단계, 이미지 3개 중 3개
    • If all works, remove the SIM card and battery.
    • Recheck the label is it on the top of the green case
    • Screws up all 6 screws
    • Put back all battery and SIM card
    • Close the back case and lock it
    • Close the USB cover
    • Done
    댓글 쓰기
  11. Disassembling Motorola Defy XT: 11 단계, 이미지 3개 중 1개 Disassembling Motorola Defy XT: 11 단계, 이미지 3개 중 2개 Disassembling Motorola Defy XT: 11 단계, 이미지 3개 중 3개
    • If you want to explore what inside of the battery with PCB. Here is the step to follow.
    • Remove the label
    • Remove the black rubber
    • Tear the battery by hand (Be patient to repeat it many time) ***do not use any metal tools to cut it out!!
    • Also you can tear PCB by hand
    댓글 쓰기
  12. Disassembling Motorola Defy XT: 12 단계, 이미지 1개 중 1개
    • Remove the black rubber Tear the battery by hand (Be patient to repeat it many time)
    댓글 쓰기
  13. Disassembling Motorola Defy XT: 13 단계, 이미지 1개 중 1개
    • ***do not use any metal tools to cut it out!!
    댓글 쓰기
  14. Disassembling Motorola Defy XT: 14 단계, 이미지 1개 중 1개
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Wing Nga PANG
회원 가입일: 08/25/14
151 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 54
전체 시간: 1,309
