주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Motorola i850 Keypad
필요한 것
  1. Disassembling Motorola i850 Keypad, Disassembling Motorola i850 Back Cover: 1 단계, 이미지 1개 중 1개
    • Use your thumb to slide the back cover locker away from the antenna.
  2. Disassembling Motorola i850 Keypad: 2 단계, 이미지 2개 중 1개 Disassembling Motorola i850 Keypad: 2 단계, 이미지 2개 중 2개
    • Slide the back cover towards the antenna while lifting the cover away from the phone.
  3. Disassembling Motorola i850 Keypad, Battery: 3 단계, 이미지 1개 중 1개
    • Place your thumb on the indicated corner while stabilizing the phone and the upper portion of the battery with your forefinger.
  4. Disassembling Motorola i850 Keypad: 4 단계, 이미지 2개 중 1개 Disassembling Motorola i850 Keypad: 4 단계, 이미지 2개 중 2개
    • Lift the battery out of the phone while pushing it towards the antenna.
  5. Disassembling Motorola i850 Keypad, Keypad: 5 단계, 이미지 1개 중 1개
    • Once battery is removed, untighten the screws located near the edges of the device with a Phillips #00 Screwdriver.
  6. Disassembling Motorola i850 Keypad: 6 단계, 이미지 3개 중 1개 Disassembling Motorola i850 Keypad: 6 단계, 이미지 3개 중 2개 Disassembling Motorola i850 Keypad: 6 단계, 이미지 3개 중 3개
    • Grip the device firmly with both hands and carefully open the device.
    • Warning: Be incredibly careful removing the back panel as you may tear the flex cable connecting the loudspeaker and side buttons.
  7. Disassembling Motorola i850 Keypad: 7 단계, 이미지 2개 중 1개 Disassembling Motorola i850 Keypad: 7 단계, 이미지 2개 중 2개
    • Carefully remove the hardware by gripping the side of the hardware attachment with a tweezer.
  8. Disassembling Motorola i850 Keypad: 8 단계, 이미지 2개 중 1개 Disassembling Motorola i850 Keypad: 8 단계, 이미지 2개 중 2개
    • Carefully grip the side of the hardware attachment with a tweezer and detach from device.
  9. Disassembling Motorola i850 Keypad: 9 단계, 이미지 3개 중 1개 Disassembling Motorola i850 Keypad: 9 단계, 이미지 3개 중 2개 Disassembling Motorola i850 Keypad: 9 단계, 이미지 3개 중 3개
    • Place the back of the device on your hand and flip it over with the other hand.
    • Carefully lift the device to remove interior hardware.
    • The structure of the keypad should easily be loose from flipping the device.
  10. Disassembling Motorola i850 Keypad: 10 단계, 이미지 3개 중 1개 Disassembling Motorola i850 Keypad: 10 단계, 이미지 3개 중 2개 Disassembling Motorola i850 Keypad: 10 단계, 이미지 3개 중 3개
    • Carefully remove the keypad by griping on the side of the plastic with a tweezer.
    • WARNING: The plastic keypad is sensitive and can be easily damaged.
결론
작성자
4다른 기여자 명과 함께
Tony Chen
회원 가입일: 04/08/10
1 평판
안내서 1개를 작성함
Cal Poly, Team 34-56, Forte Spring 2010 Cal Poly, Team 34-56, Forte Spring 2010 회원
CPSU-FORTE-S10S34G56
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 37
전체 시간: 1,872
