주요 콘텐츠로 건너뛰기
Disassembling Nano 7/LINK (A/B/C-N Serial) Panels
필요한 것
  1. Disassembling Nano 7/LINK (A/B/C-N Serial) Panels, Removing Panel Screws: 1 단계, 이미지 2개 중 1개 Disassembling Nano 7/LINK (A/B/C-N Serial) Panels, Removing Panel Screws: 1 단계, 이미지 2개 중 2개
    • Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
  2. Disassembling Nano 7/LINK (A/B/C-N Serial) Panels, Lift the closure: 2 단계, 이미지 2개 중 1개 Disassembling Nano 7/LINK (A/B/C-N Serial) Panels, Lift the closure: 2 단계, 이미지 2개 중 2개
    • Hold the roaster steady while removing the plastic top/closure.
    • Panels may spring apart slightly once removed.
  3. Disassembling Nano 7/LINK (A/B/C-N Serial) Panels, Remove bottom panel screws: 3 단계, 이미지 3개 중 1개 Disassembling Nano 7/LINK (A/B/C-N Serial) Panels, Remove bottom panel screws: 3 단계, 이미지 3개 중 2개 Disassembling Nano 7/LINK (A/B/C-N Serial) Panels, Remove bottom panel screws: 3 단계, 이미지 3개 중 3개
    • Remove the 4x 2.5mm Hex screws on the bottom of the roaster.
  4. Disassembling Nano 7/LINK (A/B/C-N Serial) Panels, Remove the front panel: 4 단계, 이미지 3개 중 1개 Disassembling Nano 7/LINK (A/B/C-N Serial) Panels, Remove the front panel: 4 단계, 이미지 3개 중 2개 Disassembling Nano 7/LINK (A/B/C-N Serial) Panels, Remove the front panel: 4 단계, 이미지 3개 중 3개
    • Pull away the front panel carefully.
    • Take care not to damage the buttons while maneuvering the front panel.
  5. Disassembling Nano 7/LINK (A/B/C-N Serial) Panels, Remove rear panel: 5 단계, 이미지 3개 중 1개 Disassembling Nano 7/LINK (A/B/C-N Serial) Panels, Remove rear panel: 5 단계, 이미지 3개 중 2개 Disassembling Nano 7/LINK (A/B/C-N Serial) Panels, Remove rear panel: 5 단계, 이미지 3개 중 3개
    • Stand the roaster up again and pull away the rear panel from the chassis to expose the remaining components.
    • The mains cable is routed through the panel and it will remain attached, place the panel in a soft bag if you wish to protect the paint throughout the rest of your repairs.
결론
작성자
1다른 기여자 명과 함께
Kaffelogic
회원 가입일: 07/23/25
2,098 평판
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 13
전체 시간: 50
