주요 콘텐츠로 건너뛰기
Disassembling Nerf Recon CS-6 Shell
필요한 것
  1. Disassembling Nerf Recon CS-6 Shell, Remove Magazine: 1 단계, 이미지 1/1
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
  2. Disassembling Nerf Recon CS-6 Shell, Remove Visible Screws: 2 단계, 이미지 1/1
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
  3. Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: 3 단계, 이미지 1/2 Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: 3 단계, 이미지 2/2
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
  4. Disassembling Nerf Recon CS-6 Shell, Remove Plunger Cap: 4 단계, 이미지 1/1
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
  5. Disassembling Nerf Recon CS-6 Shell, Remove Slide Screws: 5 단계, 이미지 1/1
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
  6. Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: 6 단계, 이미지 1/2 Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: 6 단계, 이미지 2/2
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Asad Qureshi
회원 가입일: 10/22/14
586 평판
안내서 3개 작성하였습니다
Baylor, Team 8-14, Williams Fall 2014 Baylor, Team 8-14, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G14
3 회원들
안내서 6개 작성하였습니다
댓글 2개
Does anyone have a spare spring for this gun I am missing mine
The Lazy Gamer - 답글
very useful, thanks!
Sebastian Isaacs - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 56
전체 시간: 11,737
