주요 콘텐츠로 건너뛰기
Disassembling Nexus 4 Case, USB Flex, Mainboard, Headphone Jack, Screen etc.
필요한 것
동영상 개요
  1. Disassembling Nexus 4 Case, USB Flex, Mainboard, Headphone Jack, Screen etc., Case, Battery, USB Flex, Mainboard, Headphone Jack, Screen etc.: 1 단계, 이미지 1/3 Disassembling Nexus 4 Case, USB Flex, Mainboard, Headphone Jack, Screen etc., Case, Battery, USB Flex, Mainboard, Headphone Jack, Screen etc.: 1 단계, 이미지 2/3 Disassembling Nexus 4 Case, USB Flex, Mainboard, Headphone Jack, Screen etc., Case, Battery, USB Flex, Mainboard, Headphone Jack, Screen etc.: 1 단계, 이미지 3/3
    • Opening the case
결론
To reassemble your device, follow the complete video
다른 46명이 해당 안내서를 완성하였습니다.
LE55ONS
회원 가입일: 05/30/12
10,977 평판
안내서 6개 작성하였습니다
댓글 7개
fantastic video guide! thanks
Carlo - 답글
Brilliant, best that I have found.
andy brown - 답글
Thank you for this excellent video guide !
Matthieu Imbert - 답글
Thanks for the excellent guide. Your video has perfect quality, its easy to follow. With the help of your guide I was able to change the damaged screen in about 20 min.
Michael Pirker - 답글
Excellent guide. I managed to change a broken screen in a couple of hours. Well, it actually took a little longer... the digitizer was broken but the LCD looked ok so I just bought the digitizer (around $14 on ebay) and then separated the LCD from the broken digitizer. It really hard. I ended up with a broken LCD. So I bought the LCD+Digitizer ($46) and that was easy. Its working fine now.
Pedro - 답글
You sir, are awesome. Only thing I would say is that for me it was a Phillips #000 that worked. #00 was too big.
Michael Garramone - 답글
Amazing video, thank you!!!
Ivan Zipfer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 15
전체 시간: 34,654
