주요 콘텐츠로 건너뛰기
Disassembling Nikon Coolpix 5600 Flash Unit
필요한 것
  1. Disassembling Nikon Coolpix 5600 Flash Unit, Remove Screws: 1 단계, 이미지 1/3 Disassembling Nikon Coolpix 5600 Flash Unit, Remove Screws: 1 단계, 이미지 2/3 Disassembling Nikon Coolpix 5600 Flash Unit, Remove Screws: 1 단계, 이미지 3/3
    • Remove the screws from the bottom, right, and left side of camera.
  2. Disassembling Nikon Coolpix 5600 Flash Unit, Remove back: 2 단계, 이미지 1/1
    • Remove the back of the camera, this may require force.
  3. Disassembling Nikon Coolpix 5600 Flash Unit, Remove Metal Bracket: 3 단계, 이미지 1/1
    • Unscrew the right metal bracket of the viewing lens
  4. Disassembling Nikon Coolpix 5600 Flash Unit, Remove front of camera: 4 단계, 이미지 1/1
    • Unscrew the top right corner screw
  5. Disassembling Nikon Coolpix 5600 Flash Unit: 5 단계, 이미지 1/1
    • Unscrew the bottom right corner screw.
  6. Disassembling Nikon Coolpix 5600 Flash Unit: 6 단계, 이미지 1/2 Disassembling Nikon Coolpix 5600 Flash Unit: 6 단계, 이미지 2/2
    • Pull the grey circular facet that sits on the bottom outside of the camera off - may have to use force.
  7. Disassembling Nikon Coolpix 5600 Flash Unit: 7 단계, 이미지 1/2 Disassembling Nikon Coolpix 5600 Flash Unit: 7 단계, 이미지 2/2
    • Pull the front of the camera off of the mother board.
  8. Disassembling Nikon Coolpix 5600 Flash Unit, Disassembling Nikon Coolpix 5600 Flash Unit: 8 단계, 이미지 1/1
    • Unscrew the grey plastic around the screen
  9. Disassembling Nikon Coolpix 5600 Flash Unit: 9 단계, 이미지 1/1
    • Twist the grey bracket counterclockwise to remove it from the silver LCD bracket.
  10. Disassembling Nikon Coolpix 5600 Flash Unit: 10 단계, 이미지 1/1
    • Maneuver to detach the flash bulb.
  11. Disassembling Nikon Coolpix 5600 Flash Unit: 11 단계, 이미지 1/1
    • Unscrew the metal bracket under the lens
  12. Disassembling Nikon Coolpix 5600 Flash Unit: 12 단계, 이미지 1/1
    • Slide the plastic bracket through the metal bracket.
    • Remove the orange cable from the motherboard.
  13. Disassembling Nikon Coolpix 5600 Flash Unit: 14 단계, 이미지 1/1
    • Pull the black tape off.
  14. Disassembling Nikon Coolpix 5600 Flash Unit: 15 단계, 이미지 1/1
    • Unscrew the two screws underneath.
    • Remove lens
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Crista Riedy
회원 가입일: 02/12/13
406 평판
안내서 3개 작성하였습니다
Ohio State, Team 1-2, Buehl Spring 2013 Ohio State, Team 1-2, Buehl Spring 2013 회원
OSU-BUEHL-S13S1G2
2 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 725
