주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Nokia 2366i Front Display
필요한 것
  1. Disassembling Nokia 2366i Front Display, Battery: 1 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Front Display, Battery: 1 단계, 이미지 2개 중 2개
    • Turn off the phone.
    • Position the phone so that the back side is in view.
    댓글 쓰기
  2. Disassembling Nokia 2366i Front Display: 2 단계, 이미지 1개 중 1개
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
    댓글 쓰기
  3. Disassembling Nokia 2366i Front Display: 3 단계, 이미지 3개 중 1개 Disassembling Nokia 2366i Front Display: 3 단계, 이미지 3개 중 2개 Disassembling Nokia 2366i Front Display: 3 단계, 이미지 3개 중 3개
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
    댓글 쓰기
  4. Disassembling Nokia 2366i Front Display, Front Cover: 4 단계, 이미지 1개 중 1개
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
    댓글 쓰기
  5. Disassembling Nokia 2366i Front Display: 5 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Front Display: 5 단계, 이미지 2개 중 2개
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
    댓글 쓰기
  6. Disassembling Nokia 2366i Front Display: 6 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Front Display: 6 단계, 이미지 2개 중 2개
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
    댓글 쓰기
  7. Disassembling Nokia 2366i Front Display, Main Display: 7 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Front Display, Main Display: 7 단계, 이미지 2개 중 2개
    • Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
    댓글 쓰기
  8. Disassembling Nokia 2366i Front Display: 8 단계, 이미지 2개 중 1개 Disassembling Nokia 2366i Front Display: 8 단계, 이미지 2개 중 2개
    • Using the spudger, disconnect the green display cable.
    댓글 쓰기
  9. Disassembling Nokia 2366i Front Display: 9 단계, 이미지 3개 중 1개 Disassembling Nokia 2366i Front Display: 9 단계, 이미지 3개 중 2개 Disassembling Nokia 2366i Front Display: 9 단계, 이미지 3개 중 3개
    • Lift the metal casing.
    • Be careful not to pull the casing too hard because it is still attached to the phone by a wire.
    • Remove the main display from under the metal casing.
    댓글 쓰기
  10. Disassembling Nokia 2366i Front Display, Front Display: 10 단계, 이미지 3개 중 1개 Disassembling Nokia 2366i Front Display, Front Display: 10 단계, 이미지 3개 중 2개 Disassembling Nokia 2366i Front Display, Front Display: 10 단계, 이미지 3개 중 3개
    • Fold the metal casing back over.
    • Disconnect the orange front display data cable with the spudger.
    • Hold the phone so that the antenna is facing towards you.
    • Lift up and flip over the metal casing.
    댓글 쓰기
  11. Disassembling Nokia 2366i Front Display: 11 단계, 이미지 1개 중 1개
    • Using your fingers, remove the front display.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Michael Machado
회원 가입일: 01/21/11
337 평판
안내서 3개를 작성함
Cal Poly, Team 1-14, Amido Winter 2011 Cal Poly, Team 1-14, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G14
5 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 40
전체 시간: 1,329
