주요 콘텐츠로 건너뛰기
Disassembling Nokia 2366i Motherboard
필요한 것
  1. Disassembling Nokia 2366i Motherboard, Battery: 1 단계, 이미지 1/2 Disassembling Nokia 2366i Motherboard, Battery: 1 단계, 이미지 2/2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Motherboard: 2 단계, 이미지 1/1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Motherboard: 3 단계, 이미지 1/3 Disassembling Nokia 2366i Motherboard: 3 단계, 이미지 2/3 Disassembling Nokia 2366i Motherboard: 3 단계, 이미지 3/3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Motherboard, Rear Case: 4 단계, 이미지 1/2 Disassembling Nokia 2366i Motherboard, Rear Case: 4 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
  5. Disassembling Nokia 2366i Motherboard: 5 단계, 이미지 1/2 Disassembling Nokia 2366i Motherboard: 5 단계, 이미지 2/2
    • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
    • 2 screws at the bottom
    • 2 screws at the top
  6. Disassembling Nokia 2366i Motherboard: 6 단계, 이미지 1/2 Disassembling Nokia 2366i Motherboard: 6 단계, 이미지 2/2
    • Rotate the phone clockwise so the edge is facing you.
    • Insert the spudger in tabs between the outer casing and the inside frame.
    • Slide the spudger upwards.
    • This will remove the rear case of the phone.
  7. Disassembling Nokia 2366i Motherboard: 7 단계, 이미지 1/1
    • The phone should now be in two different sections.
    • 1) The rear case of the phone.
    • 2) The motherboard and the rest of the phone.
  8. Disassembling Nokia 2366i Motherboard, Motherboard: 8 단계, 이미지 1/2 Disassembling Nokia 2366i Motherboard, Motherboard: 8 단계, 이미지 2/2
    • Use the spudger to lift off the yellow clip near the top right corner of the motherboard.
  9. Disassembling Nokia 2366i Motherboard: 9 단계, 이미지 1/2 Disassembling Nokia 2366i Motherboard: 9 단계, 이미지 2/2
    • Rotate the phone counterclockwise so that the edge is facing you.
    • Use the spudger to lift the motherboard out of the base of the phone.
    • Remove the motherboard from the base of the phone.
결론
Jonathan Newman
회원 가입일: 01/21/11
486 평판
안내서 4개 작성하였습니다
Cal Poly, Team 1-14, Amido Winter 2011 Cal Poly, Team 1-14, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G14
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,496
