주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This guide show you how to access the phone's microphone, the component that receives sound when making a call.
부품
지정된 부품이 없습니다.
  1. Make sure your phone is turned off.
    • Make sure your phone is turned off.
  2. Press the button on the back of the phone and slide the back panel off.
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Retrieve your SIM card.
    • Retrieve your SIM card.
  5. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  6. Press the black tabs to release the front cover from the phone.
    • Press the black tabs to release the front cover from the phone.
  7. Remove the front cover from the phone.
    • Remove the front cover from the phone.
    • Set the front cover, as indicated, aside.
  8. Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
    • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
  9. Remove the screen assembly from the phone base.
    • Remove the screen assembly from the phone base.
    • Set the screen assembly aside.
  10. Note the location of the microphone.
    • Note the location of the microphone.
  11. Use tweezers to remove the microphone from the phone's base.
    • Use tweezers to remove the microphone from the phone's base.
  12. The microphone is now removed.
    • The microphone is now removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sterling Fuentes
회원 가입일: 2010년 04월 09일
82 평판
안내서 8개 작성하였습니다
Cal Poly, Team 29-64, Johann Spring 2010 Cal Poly, Team 29-64, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G64
3 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,998
