이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Press the button on the back of the phone and slide the back panel off.
Remove the battery by pulling it from the phone.
Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
Remove the front cover from the phone.
Set the front cover, as indicated, aside.
Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
Remove the screen assembly from the phone base.
Set the screen assembly aside.
다른 한 분이 해당 안내서를 완성하였습니다.
