주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Nokia 3100b Speaker
필요한 것
  1. Disassembling Nokia 3100b Speaker, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure your phone is turned off.
    댓글 쓰기
  2. Disassembling Nokia 3100b Speaker: 2 단계, 이미지 1개 중 1개
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
    댓글 쓰기
  3. Disassembling Nokia 3100b Speaker, SIM Card: 3 단계, 이미지 1개 중 1개
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
    댓글 쓰기
  4. Disassembling Nokia 3100b Speaker: 4 단계, 이미지 1개 중 1개
    • Retrieve your SIM card.
    댓글 쓰기
  5. Disassembling Nokia 3100b Speaker, Screen: 5 단계, 이미지 1개 중 1개
    • Separate the front cover from the main body of the phone.
    댓글 쓰기
  6. Disassembling Nokia 3100b Speaker: 6 단계, 이미지 1개 중 1개
    • Remove the six screws along the edges of the phone.
    댓글 쓰기
  7. Disassembling Nokia 3100b Speaker: 7 단계, 이미지 1개 중 1개
    • Pull the screen assembly from the base of the phone.
    댓글 쓰기
  8. Disassembling Nokia 3100b Speaker: 8 단계, 이미지 1개 중 1개
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
    댓글 쓰기
  9. Disassembling Nokia 3100b Speaker: 9 단계, 이미지 1개 중 1개
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
    댓글 쓰기
  10. Disassembling Nokia 3100b Speaker: 10 단계, 이미지 1개 중 1개
    • Gently push down on the screen to pop it off of the assembly.
    댓글 쓰기
  11. Disassembling Nokia 3100b Speaker: 11 단계, 이미지 1개 중 1개
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
    댓글 쓰기
  12. Disassembling Nokia 3100b Speaker, Speaker: 12 단계, 이미지 1개 중 1개
    • Set the screen and the tabs aside.
    댓글 쓰기
  13. Disassembling Nokia 3100b Speaker: 13 단계, 이미지 1개 중 1개
    • You can now access the speaker.
    • Note the tab on the end of the speaker. It must be placed in correctly in order to reinstall the speaker.
    댓글 쓰기
  14. Disassembling Nokia 3100b Speaker: 14 단계, 이미지 1개 중 1개
    • Remove the speaker from the assembly.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Sterling Fuentes
회원 가입일: 04/09/10
139 평판
안내서 8개를 작성함
Cal Poly, Team 29-64, Johann Spring 2010 Cal Poly, Team 29-64, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G64
3 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 54
전체 시간: 1,614
