주요 콘텐츠로 건너뛰기
Disassembling Nokia 3395 Logic Board
필요한 것
  1. Disassembling Nokia 3395 Logic Board, Back Case: 1 단계, 이미지 1/3 Disassembling Nokia 3395 Logic Board, Back Case: 1 단계, 이미지 2/3 Disassembling Nokia 3395 Logic Board, Back Case: 1 단계, 이미지 3/3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
  2. Disassembling Nokia 3395 Logic Board, Battery: 2 단계, 이미지 1/2 Disassembling Nokia 3395 Logic Board, Battery: 2 단계, 이미지 2/2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
  3. Disassembling Nokia 3395 Logic Board, Front Case: 3 단계, 이미지 1/2 Disassembling Nokia 3395 Logic Board, Front Case: 3 단계, 이미지 2/2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
  4. Disassembling Nokia 3395 Logic Board, Screen: 4 단계, 이미지 1/2 Disassembling Nokia 3395 Logic Board, Screen: 4 단계, 이미지 2/2
    • Remove six T6 screws.
  5. Disassembling Nokia 3395 Logic Board: 5 단계, 이미지 1/2 Disassembling Nokia 3395 Logic Board: 5 단계, 이미지 2/2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
  6. Disassembling Nokia 3395 Logic Board, Logic Board: 6 단계, 이미지 1/2 Disassembling Nokia 3395 Logic Board, Logic Board: 6 단계, 이미지 2/2
    • Remove logic board as shown.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nico Lee
회원 가입일: 04/19/10
78 평판
안내서 6개 작성하였습니다
Cal Poly, Team 30-41, Garner Spring 2010 Cal Poly, Team 30-41, Garner Spring 2010 회원
CPSU-GARNER-S10S30G41
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,878
