주요 콘텐츠로 건너뛰기
소개
This guide will show you how to remove the battery from the Nokia 3560.
부품
지정된 부품이 없습니다.
  1. Press down on the release latch on the bottom of the cover. Once the latch is released, lift the cover from the phone.
    • Press down on the release latch on the bottom of the cover.
    • Once the latch is released, lift the cover from the phone.
  2. Insert flat screwdriver or other flat object between battery case and housing. Lift the battery from the housing.
    • Insert flat screwdriver or other flat object between battery case and housing.
    • Lift the battery from the housing.
결론
Sam Ryan
회원 가입일: 2010년 04월 18일
1 평판
안내서 8개 작성하였습니다
Cal Poly, Team 30-39, Garner Spring 2010 Cal Poly, Team 30-39, Garner Spring 2010 회원
CPSU-GARNER-S10S30G39
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,320
