주요 콘텐츠로 건너뛰기
Disassembling Nokia 3560 Charging Port and Power Connector
필요한 것
  1. Disassembling Nokia 3560 Charging Port and Power Connector, Back Cover: 1 단계, 이미지 1/2 Disassembling Nokia 3560 Charging Port and Power Connector, Back Cover: 1 단계, 이미지 2/2
    • Press down on the release latch on the bottom of the cover.
    • Once the latch is released, lift the cover from the phone.
  2. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Keypad: 2 단계, 이미지 1/1
    • Lift the front case off of the phone body.
  3. Disassembling Nokia 3560 Charging Port and Power Connector: 3 단계, 이미지 1/2 Disassembling Nokia 3560 Charging Port and Power Connector: 3 단계, 이미지 2/2
    • Lift the keypad off of the phone.
  4. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 LCD Display: 4 단계, 이미지 1/1
    • The screen is held to the body by six screws.
  5. Disassembling Nokia 3560 Charging Port and Power Connector: 5 단계, 이미지 1/1
    • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
  6. Disassembling Nokia 3560 Charging Port and Power Connector: 6 단계, 이미지 1/2 Disassembling Nokia 3560 Charging Port and Power Connector: 6 단계, 이미지 2/2
    • Insert a flat screwdriver between the black body and plastic layer.
  7. Disassembling Nokia 3560 Charging Port and Power Connector: 7 단계, 이미지 1/1
    • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
  8. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Logic Board: 8 단계, 이미지 1/1
    • With the screws removed, the logic board can then be lifted out of the body by hand.
  9. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Charging Port and Power Connector: 9 단계, 이미지 1/2 Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Charging Port and Power Connector: 9 단계, 이미지 2/2
    • These two parts can be removed with your fingers.
    • Make sure not to bend the metal contacts.
결론
Sam Ryan
회원 가입일: 04/18/10
1 평판
안내서 8개 작성하였습니다
Cal Poly, Team 30-39, Garner Spring 2010 Cal Poly, Team 30-39, Garner Spring 2010 회원
CPSU-GARNER-S10S30G39
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 3,264
