주요 콘텐츠로 건너뛰기
Disassembling Nokia 6086 Base of The Phone
필요한 것
  1. Disassembling Nokia 6086 Base of The Phone, Battery: 1 단계, 이미지 1/1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 6086 Base of The Phone: 2 단계, 이미지 1/3 Disassembling Nokia 6086 Base of The Phone: 2 단계, 이미지 2/3 Disassembling Nokia 6086 Base of The Phone: 2 단계, 이미지 3/3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Disassembling Nokia 6086 Base of The Phone: 3 단계, 이미지 1/3 Disassembling Nokia 6086 Base of The Phone: 3 단계, 이미지 2/3 Disassembling Nokia 6086 Base of The Phone: 3 단계, 이미지 3/3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. Disassembling Nokia 6086 Base of The Phone, Upper Back Cover: 4 단계, 이미지 1/1
    • Turn the phone so that the back of the phone is facing forward.
    • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
  5. Disassembling Nokia 6086 Base of The Phone: 5 단계, 이미지 1/2 Disassembling Nokia 6086 Base of The Phone: 5 단계, 이미지 2/2
    • Place the iPod opening tool under the tabs near the top of the phone.
    • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
    • Repeat for the left and the right sides.
  6. Disassembling Nokia 6086 Base of The Phone: 6 단계, 이미지 1/2 Disassembling Nokia 6086 Base of The Phone: 6 단계, 이미지 2/2
    • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
    • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
  7. Disassembling Nokia 6086 Base of The Phone: 7 단계, 이미지 1/3 Disassembling Nokia 6086 Base of The Phone: 7 단계, 이미지 2/3 Disassembling Nokia 6086 Base of The Phone: 7 단계, 이미지 3/3
    • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
  8. Disassembling Nokia 6086 Base of The Phone, Base of The Phone: 8 단계, 이미지 1/2 Disassembling Nokia 6086 Base of The Phone, Base of The Phone: 8 단계, 이미지 2/2
    • Locate the four screws.
    • Remove the screws using a T6 Torx screwdriver.
  9. Disassembling Nokia 6086 Base of The Phone: 9 단계, 이미지 1/2 Disassembling Nokia 6086 Base of The Phone: 9 단계, 이미지 2/2
    • Turn the phone over.
    • Gently pull apart the phone.
    • Start at the bottom of the phone and pull outward.
    • There are plastic catches on the middle of each side. These should pop free as you pull.
    • Be careful, the phone will separate into two sections.
  10. Disassembling Nokia 6086 Base of The Phone: 10 단계, 이미지 1/2 Disassembling Nokia 6086 Base of The Phone: 10 단계, 이미지 2/2
    • The phone should now be in two different sections.
    • 1) The logic board and the back cover
    • 2) The keypad and the rest of the phone
결론
다른 2명이 해당 안내서를 완성하였습니다.
Andrea
회원 가입일: 04/15/10
70 평판
안내서 5개 작성하였습니다
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010 회원
CPSU-REGAN-S10S26G30
4 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 3,636
