주요 콘텐츠로 건너뛰기
Disassembling Nokia 6086 Top Front Cover
필요한 것
  1. Disassembling Nokia 6086 Top Front Cover, Battery: 1 단계, 이미지 1/1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 6086 Top Front Cover: 2 단계, 이미지 1/3 Disassembling Nokia 6086 Top Front Cover: 2 단계, 이미지 2/3 Disassembling Nokia 6086 Top Front Cover: 2 단계, 이미지 3/3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Disassembling Nokia 6086 Top Front Cover: 3 단계, 이미지 1/3 Disassembling Nokia 6086 Top Front Cover: 3 단계, 이미지 2/3 Disassembling Nokia 6086 Top Front Cover: 3 단계, 이미지 3/3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. Disassembling Nokia 6086 Top Front Cover, Top Front Cover: 4 단계, 이미지 1/1
    • Close the phone.
    • Face the front cover forward.
  5. Disassembling Nokia 6086 Top Front Cover: 5 단계, 이미지 1/2 Disassembling Nokia 6086 Top Front Cover: 5 단계, 이미지 2/2
    • Locate the 4.5 mm notch at the top of the phone.
    • Place the iPod opening tool into the opening.
    • Slightly prop up the top section by lifting the tool.
  6. Disassembling Nokia 6086 Top Front Cover: 6 단계, 이미지 1/3 Disassembling Nokia 6086 Top Front Cover: 6 단계, 이미지 2/3 Disassembling Nokia 6086 Top Front Cover: 6 단계, 이미지 3/3
    • Wedge the iPod opening tool between the top cover and the phone.
    • Gently lift the top cover away from the phone using the iPod opening tool.
    • This unlatches each hook that connects the top cover to the phone.
    • Repeat for both the left and the right sides of the phone.
    • Place the top cover aside once the top cover is completely disconnected from the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrea
회원 가입일: 04/15/10
70 평판
안내서 5개 작성하였습니다
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010 회원
CPSU-REGAN-S10S26G30
4 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 16
30일 전: 18
전체 시간: 2,228
