주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Nokia 6086 Upper Back Cover
필요한 것
  1. Disassembling Nokia 6086 Upper Back Cover, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 6086 Upper Back Cover: 2 단계, 이미지 3개 중 1개 Disassembling Nokia 6086 Upper Back Cover: 2 단계, 이미지 3개 중 2개 Disassembling Nokia 6086 Upper Back Cover: 2 단계, 이미지 3개 중 3개
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Disassembling Nokia 6086 Upper Back Cover: 3 단계, 이미지 3개 중 1개 Disassembling Nokia 6086 Upper Back Cover: 3 단계, 이미지 3개 중 2개 Disassembling Nokia 6086 Upper Back Cover: 3 단계, 이미지 3개 중 3개
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. Disassembling Nokia 6086 Upper Back Cover, Upper Back Cover: 4 단계, 이미지 1개 중 1개
    • Turn the phone so that the back of the phone is facing forward.
    • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
  5. Disassembling Nokia 6086 Upper Back Cover: 5 단계, 이미지 2개 중 1개 Disassembling Nokia 6086 Upper Back Cover: 5 단계, 이미지 2개 중 2개
    • Place the iPod opening tool under the tabs near the top of the phone.
    • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
    • Repeat for the left and the right sides.
  6. Disassembling Nokia 6086 Upper Back Cover: 6 단계, 이미지 2개 중 1개 Disassembling Nokia 6086 Upper Back Cover: 6 단계, 이미지 2개 중 2개
    • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
    • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
  7. Disassembling Nokia 6086 Upper Back Cover: 7 단계, 이미지 3개 중 1개 Disassembling Nokia 6086 Upper Back Cover: 7 단계, 이미지 3개 중 2개 Disassembling Nokia 6086 Upper Back Cover: 7 단계, 이미지 3개 중 3개
    • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
결론
작성자
5다른 기여자 명과 함께
Andrea
회원 가입일: 04/15/10
70 평판
안내서 5개를 작성함
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010 회원
CPSU-REGAN-S10S26G30
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 75
전체 시간: 2,529
