주요 콘텐츠로 건너뛰기
Disassembling Nokia 6236i Display
필요한 것
  1. Disassembling Nokia 6236i Display, Battery: 1 단계, 이미지 1/2 Disassembling Nokia 6236i Display, Battery: 1 단계, 이미지 2/2
    • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Disassembling Nokia 6236i Display: 2 단계, 이미지 1/3 Disassembling Nokia 6236i Display: 2 단계, 이미지 2/3 Disassembling Nokia 6236i Display: 2 단계, 이미지 3/3
    • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
    • The battery should lift out with minimal resistance.
  3. Disassembling Nokia 6236i Display, Front Casing: 3 단계, 이미지 1/3 Disassembling Nokia 6236i Display, Front Casing: 3 단계, 이미지 2/3 Disassembling Nokia 6236i Display, Front Casing: 3 단계, 이미지 3/3
    • Insert a spudger into the indention on the bottom right side of the device.
    • Slide the spudger upward to a second indention at the top of the phone.
    • The front casing will detach from the phone.
  4. Disassembling Nokia 6236i Display, Disassembling Nokia 6236i Display: 4 단계, 이미지 1/3 Disassembling Nokia 6236i Display, Disassembling Nokia 6236i Display: 4 단계, 이미지 2/3 Disassembling Nokia 6236i Display, Disassembling Nokia 6236i Display: 4 단계, 이미지 3/3
    • Use the flathead screwdriver to remove four screws on the upper half of the phone.
    • Lift the LCD up and off.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Erik Lindahl
회원 가입일: 04/18/10
63 평판
안내서 4개 작성하였습니다
Cal Poly, Team 10-46, Garner Spring 2010 Cal Poly, Team 10-46, Garner Spring 2010 회원
CPSU-GARNER-S10S10G46
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 1,582
