주요 콘텐츠로 건너뛰기
Nokia 6236i Front Casing Replacement
필요한 것
  1. Nokia 6236i Front Casing Replacement, Battery: 1 단계, 이미지 1/2 Nokia 6236i Front Casing Replacement, Battery: 1 단계, 이미지 2/2
    • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Nokia 6236i Front Casing Replacement: 2 단계, 이미지 1/3 Nokia 6236i Front Casing Replacement: 2 단계, 이미지 2/3 Nokia 6236i Front Casing Replacement: 2 단계, 이미지 3/3
    • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
    • The battery should lift out with minimal resistance.
  3. Nokia 6236i Front Casing Replacement, SIM Card: 3 단계, 이미지 1/3 Nokia 6236i Front Casing Replacement, SIM Card: 3 단계, 이미지 2/3 Nokia 6236i Front Casing Replacement, SIM Card: 3 단계, 이미지 3/3
    • Once the battery is removed, pull the tab of the metal sim card cover, and lift it up.
    • The sim card is underneath and can now be removed.
  4. Nokia 6236i Front Casing Replacement, Front Casing: 4 단계, 이미지 1/3 Nokia 6236i Front Casing Replacement, Front Casing: 4 단계, 이미지 2/3 Nokia 6236i Front Casing Replacement, Front Casing: 4 단계, 이미지 3/3
    • Insert a spudger into the indention on the bottom right side of the device.
    • Slide the spudger upward to a second indention at the top of the phone.
    • The front casing will detach from the phone.
결론
The front casing will be detached without causing damage to the case or phone model.
For reassembly, complete the listed steps in reverse.
Erik Lindahl
회원 가입일: 04/18/10
63 평판
안내서 4개 작성하였습니다
Cal Poly, Team 10-46, Garner Spring 2010 Cal Poly, Team 10-46, Garner Spring 2010 회원
CPSU-GARNER-S10S10G46
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,854
