소개
This guides you through removing the keypad.
부품
부품은 필요하지 않습니다.
  1. Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone. Lift the battery case off of the phone.
    • Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone. The battery should lift out with minimal resistance. The battery should lift out with minimal resistance.
    • Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone.
    • The battery should lift out with minimal resistance.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Locate the notch on the bottom right corner of the phone. Beginning at this point, slide the head of the screwdriver between the front casing and the rest of the phone. Continue to slide the screwdriver towards the top edge of the phone.
    • Locate the notch on the bottom right corner of the phone.
    • Beginning at this point, slide the head of the screwdriver between the front casing and the rest of the phone.
    • Continue to slide the screwdriver towards the top edge of the phone.
    • The front casing should eventually pop off.
  5. With the front casing removed, the keypad can easily be pulled off the back of the front casing.
    • With the front casing removed, the keypad can easily be pulled off the back of the front casing.
    • In all probability, it will already have fallen out and no removal is required.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Erik Lindahl
회원 가입일: 2010년 04월 18일
48 평판
안내서 4개 작성하였습니다
Cal Poly, Team 10-46, Garner Spring 2010 Cal Poly, Team 10-46, Garner Spring 2010 회원
CPSU-GARNER-S10S10G46
4 회원들
안내서 10개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 869
