주요 콘텐츠로 건너뛰기
Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly
필요한 것
  1. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Battery: 1 단계, 이미지 1/2 Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Battery: 1 단계, 이미지 2/2
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 2 단계, 이미지 1/1
    • To remove the battery, push it down from the top and pull it out.
  3. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 3 단계, 이미지 1/1
    • Grip the front cover from the bottom.
  4. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 4 단계, 이미지 1/1
    • Lift the front cover off.
  5. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 5 단계, 이미지 1/1
    • Remove the six screws using a T6 torx screwdriver.
  6. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 6 단계, 이미지 1/1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 7 단계, 이미지 1/1
    • Remove assembly from phone
결론
Colby Leslie
회원 가입일: 10/05/10
1 평판
안내서 7개 작성하였습니다
Cal Poly, Team 22-3, Maness Fall 2010 Cal Poly, Team 22-3, Maness Fall 2010 회원
CPSU-MANESS-F10S22G3
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,055
