주요 콘텐츠로 건너뛰기
Disassembling Nokia E61i Speaker
필요한 것
  1. Disassembling Nokia E61i Speaker, Battery: 1 단계, 이미지 1/2 Disassembling Nokia E61i Speaker, Battery: 1 단계, 이미지 2/2
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Disassembling Nokia E61i Speaker: 2 단계, 이미지 1/1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Disassembling Nokia E61i Speaker: 3 단계, 이미지 1/1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Disassembling Nokia E61i Speaker, Front Cover: 4 단계, 이미지 1/2 Disassembling Nokia E61i Speaker, Front Cover: 4 단계, 이미지 2/2
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Disassembling Nokia E61i Speaker: 5 단계, 이미지 1/1
    • Remove the cover by pulling it up and off.
  6. Disassembling Nokia E61i Speaker, Display: 6 단계, 이미지 1/2 Disassembling Nokia E61i Speaker, Display: 6 단계, 이미지 2/2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Disassembling Nokia E61i Speaker: 7 단계, 이미지 1/2 Disassembling Nokia E61i Speaker: 7 단계, 이미지 2/2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Disassembling Nokia E61i Speaker, Speaker: 8 단계, 이미지 1/2 Disassembling Nokia E61i Speaker, Speaker: 8 단계, 이미지 2/2
    • Remove the speaker by pulling it off of the display frame.
    • The speaker is connected to the display frame by a ring of adhesive foam (visible in second picture). By removing the speaker, this foam is torn. However, the speaker sticks quite well to the frame without reapplication of any adhesive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher Patton
회원 가입일: 04/07/11
208 평판
안내서 12개 작성하였습니다
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011 회원
CPSU-WALTERS-S11S9G63
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,833
