주요 콘텐츠로 건너뛰기
Disassembling Nokia E71 Complete disassembly
필요한 것
  1. Disassembling Nokia E71 Complete disassembly, Disassembling Nokia E71 Complete disassembly: 1 단계, 이미지 1개 중 1개
    • First remove back cover, battery, chip and memory card .
  2. Disassembling Nokia E71 Complete disassembly: 2 단계, 이미지 2개 중 1개 Disassembling Nokia E71 Complete disassembly: 2 단계, 이미지 2개 중 2개
    • Remove 4 Torx T5 screws.
  3. Disassembling Nokia E71 Complete disassembly: 3 단계, 이미지 2개 중 1개 Disassembling Nokia E71 Complete disassembly: 3 단계, 이미지 2개 중 2개
    • Press these four latches (each side has two) to open front cover.
  4. Disassembling Nokia E71 Complete disassembly: 4 단계, 이미지 1개 중 1개
    • Carefully remove the front cover with blade tool.
  5. Disassembling Nokia E71 Complete disassembly: 5 단계, 이미지 2개 중 1개 Disassembling Nokia E71 Complete disassembly: 5 단계, 이미지 2개 중 2개
    • Carefully remove the bottom cover. This cover has no screws, only latches.
  6. Disassembling Nokia E71 Complete disassembly: 6 단계, 이미지 1개 중 1개
    • Front cover, rubber keyboard and bottom cover removed.
  7. Disassembling Nokia E71 Complete disassembly: 7 단계, 이미지 2개 중 1개 Disassembling Nokia E71 Complete disassembly: 7 단계, 이미지 2개 중 2개
    • Remove these two Torx T6 screws at top of the smartphone.
  8. Disassembling Nokia E71 Complete disassembly: 8 단계, 이미지 1개 중 1개
    • Carefully remove the assembly. Dont forget to move away the plastic clip holding the assembly down. You can find this in the center on the bottom.
  9. Disassembling Nokia E71 Complete disassembly: 9 단계, 이미지 1개 중 1개
    • Base assembly with small connectors and parts.
  10. Disassembling Nokia E71 Complete disassembly: 10 단계, 이미지 1개 중 1개
    • Remove the LCD connector.
  11. Disassembling Nokia E71 Complete disassembly: 11 단계, 이미지 1개 중 1개
    • Carefully open the LCD and keyboard assembly, and remove keyboard connector.
  12. Disassembling Nokia E71 Complete disassembly: 12 단계, 이미지 2개 중 1개 Disassembling Nokia E71 Complete disassembly: 12 단계, 이미지 2개 중 2개
    • Both sides of the LCD and keyboard assembly removed.
  13. Disassembling Nokia E71 Complete disassembly: 13 단계, 이미지 1개 중 1개
    • I think that two small blocks are the gps antenna.
  14. Disassembling Nokia E71 Complete disassembly: 14 단계, 이미지 2개 중 1개 Disassembling Nokia E71 Complete disassembly: 14 단계, 이미지 2개 중 2개
    • Both sides of battery - for reference only.
결론
다른 33명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jose Gustavo Abreu Murta
회원 가입일: 07/06/10
4,970 평판
안내서 9개를 작성함
4가이드 댓글
does anyone know if e71 have any battery on board? time and date keep resetting with battery removed.
cyfcyf - 답글
Yes there is, under the keypad, 3/4 of the way down the left side of looking from the front. It is soldered on to the board so take good care.
Samuel Wyatt -
Hi
I have this phone, but I can not charge it ,Because it has short in board ,plus it very short charger soket (female ), i’m use now extirnal charger only
what can i do ?
Dev Abokhadra - 답글
Very clear tutorial !
The pictures are well lit, and the instructions are good :)
Thanks !
James Burton - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 71
전체 시간: 34,554
