이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Carefully remove the bottom cover. This cover has no screws, only latches.
Carefully remove the assembly. Dont forget to move away the plastic clip holding the assembly down. You can find this in the center on the bottom.
Carefully open the LCD and keyboard assembly, and remove keyboard connector.
다른 33명이 해당 안내서를 완성하였습니다.
댓글 4개
does anyone know if e71 have any battery on board? time and date keep resetting with battery removed.
Yes there is, under the keypad, 3/4 of the way down the left side of looking from the front. It is soldered on to the board so take good care.
Hi
I have this phone, but I can not charge it ,Because it has short in board ,plus it very short charger soket (female ), i’m use now extirnal charger only
what can i do ?
Very clear tutorial !
The pictures are well lit, and the instructions are good :)
Thanks !
