주요 콘텐츠로 건너뛰기
Disassembling Nokia X2-00
필요한 것
  1. Disassembling Nokia X2-00, Nokia X2-00 Background Info: 1 단계, 이미지 1/1
    • it's a cheap low-end Music Phone
    • mine got wet so i decided to clean it up and look inside!
  2. Disassembling Nokia X2-00, Removing the Battery: 2 단계, 이미지 1/3 Disassembling Nokia X2-00, Removing the Battery: 2 단계, 이미지 2/3 Disassembling Nokia X2-00, Removing the Battery: 2 단계, 이미지 3/3
    • Flip it and pull the tab
    • the metal part should jump right off
    • after that remove the battery and sim card
  3. Disassembling Nokia X2-00, Diging In!: 3 단계, 이미지 1/1
    • so i was kinda !#^&@@ off becouse there were no screws!
    • so i tryed to remove the screen protection, and it worked!
    • 1. i did break it
    • 2. there were no screws
    • just don't do that unless you need
  4. Disassembling Nokia X2-00, Diging In! 2nd attemp!: 4 단계, 이미지 1/2 Disassembling Nokia X2-00, Diging In! 2nd attemp!: 4 단계, 이미지 2/2
    • i tried to remove the side panels but that didn't work so i tried on top and it did work (Jimmy worked fine)
    • these clips kind of suck ....it takes lot of force to unclip these )
    • after you unclip it you get that piece
  5. Disassembling Nokia X2-00, Removing the midframe: 5 단계, 이미지 1/3 Disassembling Nokia X2-00, Removing the midframe: 5 단계, 이미지 2/3 Disassembling Nokia X2-00, Removing the midframe: 5 단계, 이미지 3/3
    • remove these 2 TR6 Screws (mine were a bit blue)
    • open it up (clips on the bottom)
    • i was on Beast-Mode on these annying clips that held like gorilla
  6. Disassembling Nokia X2-00, Removing the display: 6 단계, 이미지 1/3 Disassembling Nokia X2-00, Removing the display: 6 단계, 이미지 2/3 Disassembling Nokia X2-00, Removing the display: 6 단계, 이미지 3/3
    • Remove the 4 TR6 Screws
    • They are diffrent from the last ones !!! (this one on the right)
    • remove the whole PCB and remove the clips from the display and it should pop off
  7. Disassembling Nokia X2-00, The Display: 7 단계, 이미지 1/2 Disassembling Nokia X2-00, The Display: 7 단계, 이미지 2/2
    • it's TFT 2.2" 240x320 182 ppi Display
  8. Disassembling Nokia X2-00, The main PCB: 8 단계, 이미지 1/1
    • anything shiehielded ...and non-replacable ...i don't like that one at all
    • sorry guys i have forgott to make photo of the backside :(
  9. Disassembling Nokia X2-00, Extra - Mastery pieces & Test: 9 단계, 이미지 1/2 Disassembling Nokia X2-00, Extra - Mastery pieces & Test: 9 단계, 이미지 2/2
    • extra steps that you don't need to do
    • 2 of those fell of and i have NO idea where from (and i don't even care)
    • i cleaned it up and powered it up and it works (just make sure you don't short anything)
  10. Disassembling Nokia X2-00, The END: 10 단계, 이미지 1/1
    • i don't really like that one becouse it's hard to open and easy to crack plastics
    • but you can replace many things (not anything)
    • i would like USB on doughterboard and less shielding
결승점
다른 9명이 해당 안내서를 완성하였습니다.
Mateusz
회원 가입일: 10/20/14
1,498 평판
안내서 2개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 23
전체 시간: 5,036
