주요 콘텐츠로 건너뛰기
Disassembling Numark TT1600 Circuit board
필요한 것
  1. Disassembling Numark TT1600 Circuit board, Circuit board: 1 단계, 이미지 1/2 Disassembling Numark TT1600 Circuit board, Circuit board: 1 단계, 이미지 2/2
    • Flip over the turntable and remove the nine screws on the outer edges.
  2. Disassembling Numark TT1600 Circuit board: 2 단계, 이미지 1/1
    • Remove the back cover by pulling it apart.
  3. Disassembling Numark TT1600 Circuit board: 3 단계, 이미지 1/1
    • Locate the largest circuit board inside the device.
  4. Disassembling Numark TT1600 Circuit board: 4 단계, 이미지 1/1
    • Locate the wires that are plugged into the side of the circuit board.
  5. Disassembling Numark TT1600 Circuit board: 5 단계, 이미지 1/2 Disassembling Numark TT1600 Circuit board: 5 단계, 이미지 2/2
    • Gently pull out the wires plugged into the circuit board.
  6. Disassembling Numark TT1600 Circuit board: 6 단계, 이미지 1/2 Disassembling Numark TT1600 Circuit board: 6 단계, 이미지 2/2
    • Once the wires are unplugged you will notice two more wires plugged into the bottom of the circuit board.
    • Note that these wires are soldered onto the circuit, indicated by the red markers.
    • To completely remove the circuit board these wires must be removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sukhjinder
회원 가입일: 10/12/11
17 평판
안내서 1개 작성함
Cal Poly, Team 17-14, Regan Fall 2011 Cal Poly, Team 17-14, Regan Fall 2011 회원
CPSU-REGAN-F11S17G14
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 12
전체 시간: 1,523
