주요 콘텐츠로 건너뛰기
Disassembling Olympus FE-170 Casing
필요한 것
  1. Disassembling Olympus FE-170 Casing, Casing: 1 단계, 이미지 1/2 Disassembling Olympus FE-170 Casing, Casing: 1 단계, 이미지 2/2
    • Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
  2. Disassembling Olympus FE-170 Casing: 2 단계, 이미지 1/2 Disassembling Olympus FE-170 Casing: 2 단계, 이미지 2/2
    • Open the battery compartment and remove the 2 screws in the top of the opening.
  3. Disassembling Olympus FE-170 Casing: 3 단계, 이미지 1/2 Disassembling Olympus FE-170 Casing: 3 단계, 이미지 2/2
    • Remove the 2 exposed screws on the bottom of the camera.
  4. Disassembling Olympus FE-170 Casing: 4 단계, 이미지 1/1
    • Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
  5. Disassembling Olympus FE-170 Casing: 5 단계, 이미지 1/1
    • Uncover the video cable port on the side of the camera and remove the screw
  6. Disassembling Olympus FE-170 Casing: 6 단계, 이미지 1/2 Disassembling Olympus FE-170 Casing: 6 단계, 이미지 2/2
    • Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
  7. Disassembling Olympus FE-170 Casing: 7 단계, 이미지 1/2 Disassembling Olympus FE-170 Casing: 7 단계, 이미지 2/2
    • Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
  8. Disassembling Olympus FE-170 Casing: 8 단계, 이미지 1/2 Disassembling Olympus FE-170 Casing: 8 단계, 이미지 2/2
    • Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
결론
CCrane
회원 가입일: 03/26/15
201 평판
안내서 2개 작성하였습니다
Baylor, Team 6-4, Shaver Spring 2015 Baylor, Team 6-4, Shaver Spring 2015 회원
BU-SHAVER-S15S6G4
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 19
전체 시간: 396
