주요 콘텐츠로 건너뛰기
Disassembling Olympus Stylus 1010 Case
필요한 것
  1. Disassembling Olympus Stylus 1010 Case, Disassembling Olympus Stylus 1010 Case: 1 단계, 이미지 1/2 Disassembling Olympus Stylus 1010 Case, Disassembling Olympus Stylus 1010 Case: 1 단계, 이미지 2/2
    • Remove the five Phillips #00 bottom and right side panel screws.
    Put a notice on here that the screws are very small and are easy to misplace while disassembling device. Also, while disassembling the device there was only one screw present, where the guide suggested there were three.
    Curtis Reedy - 답글
    Before beginning, put a note that the camera should be turned off before proceeding.
    Curtis Reedy - 답글
    Add a note at the beginning of the guide that there are a large number of small screws that should be separated as the steps are completed.
    Curtis Reedy - 답글
    There's a capacitor .....watch out for it in every step.
    BILL BOYD - 답글
  2. Disassembling Olympus Stylus 1010 Case: 2 단계, 이미지 1/1
    • Remove the right side panel by pulling off the large silver piece.
    There is no reference to removing screws from the right side panel, where it is necessary to remove 2 screws to do so.
    Curtis Reedy - 답글
  3. Disassembling Olympus Stylus 1010 Case: 3 단계, 이미지 1/2 Disassembling Olympus Stylus 1010 Case: 3 단계, 이미지 2/2
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Disassembling Olympus Stylus 1010 Case: 4 단계, 이미지 1/1
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Disassembling Olympus Stylus 1010 Case: 5 단계, 이미지 1/1
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Disassembling Olympus Stylus 1010 Case: 6 단계, 이미지 1/3 Disassembling Olympus Stylus 1010 Case: 6 단계, 이미지 2/3 Disassembling Olympus Stylus 1010 Case: 6 단계, 이미지 3/3
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
    Wrong point of focus for the second picture. What should be in focus is very blurry.
    Curtis Reedy - 답글
  7. Disassembling Olympus Stylus 1010 Case: 7 단계, 이미지 1/3 Disassembling Olympus Stylus 1010 Case: 7 단계, 이미지 2/3 Disassembling Olympus Stylus 1010 Case: 7 단계, 이미지 3/3
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
    There were multiple gold strips, so the one that needs to be pulled should be highlited in the picture.
    Curtis Reedy - 답글
    in step seven pull up the black bar of the ZIF connectors before pulling out the white or gold ribbons
    Curtis Reedy - 답글
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Max McIntyre
회원 가입일: 01/21/11
526 평판
안내서 4개 작성하였습니다
Cal Poly, Team 13-4, Forte Winter 2011 Cal Poly, Team 13-4, Forte Winter 2011 회원
CPSU-FORTE-W11S13G4
6 회원들
안내서 12개 작성하였습니다
댓글 한 개
How did you get the ring around the lens off?? I can't seem to find that step and in all the pictures it's already off
Maureen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 3,022
