부품
부품은 필요하지 않습니다.
  1. Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws) Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws)
    • Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws)
  2. Remove the right side panel by pulling off the large silver piece.
    • Remove the right side panel by pulling off the large silver piece.
  3. Unscrew the remaining side and front panel screws using a #00 screwdriver. (3 screws) Unscrew the remaining side and front panel screws using a #00 screwdriver. (3 screws)
    • Unscrew the remaining side and front panel screws using a #00 screwdriver. (3 screws)
  4. Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece. (2 pieces)
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece. (2 pieces)
  5. Remove the black front panel by sliding it towards the lens and then pulling it up off the camera.
    • Remove the black front panel by sliding it towards the lens and then pulling it up off the camera.
  6. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  7. Remove 3 screws from the front of the camera using a #00 screwdriver. Lift the two tabs to separate the case using a spudger. (one tab on top and one tab on the right side) Lift the two tabs to separate the case using a spudger. (one tab on top and one tab on the right side)
    • Remove 3 screws from the front of the camera using a #00 screwdriver.
    • Lift the two tabs to separate the case using a spudger. (one tab on top and one tab on the right side)
  8. Using a plastic spudger, lift up the black clips. Still using the plastic spudger, detach the gold connector strip and white connector strip. Using both hands, pull the camera apart into two pieces.
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
  9. Using a plastic spudger, lift up the black clips. Still using the spudger, detach the 3 gold wire tape connectors from the inside of the camera.
    • Still using the spudger, detach the 3 gold wire tape connectors from the inside of the camera.
  10. Remove 3 screws from the inside of the camera using a #00 screwdriver.
    • Remove 3 screws from the inside of the camera using a #00 screwdriver.
  11. Using your thumb and forefinger, pull the lens piece straight out from the body of the camera. Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
    • Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
  12. Unscrew two screws on the right side of the camera using a #00 screwdriver.
    • Unscrew two screws on the right side of the camera using a #00 screwdriver.
  13. Using a plastic spudger, lift up the black clips.
    • Still using the spudger, detach the gold wire tape connectors from the logic board.
  14. Unsolder the upper right and lower left wires to remove logic board.
    • Unsolder the upper right and lower left wires to remove logic board.
  15. In order to remove the logic board, grab each side of it and pull up using your thumb and forefinger. In order to remove the logic board, grab each side of it and pull up using your thumb and forefinger.
    • In order to remove the logic board, grab each side of it and pull up using your thumb and forefinger.
결론
Max McIntyre
회원 가입일: 2011년 01월 21일
511 평판
안내서 4개 작성하였습니다
Cal Poly, Team 13-4, Forte Winter 2011 Cal Poly, Team 13-4, Forte Winter 2011 회원
CPSU-FORTE-W11S13G4
6 회원들
안내서 6개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 2,969
