주요 콘텐츠로 건너뛰기
Olympus Stylus 1010 Motherboard Replacement
필요한 것
  1. Olympus Stylus 1010 Motherboard Replacement, Disassembling Olympus Stylus 1010 Case: 1 단계, 이미지 1/2 Olympus Stylus 1010 Motherboard Replacement, Disassembling Olympus Stylus 1010 Case: 1 단계, 이미지 2/2
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Olympus Stylus 1010 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the right side panel by pulling off the large silver piece.
  3. Olympus Stylus 1010 Motherboard Replacement: 3 단계, 이미지 1/2 Olympus Stylus 1010 Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Olympus Stylus 1010 Motherboard Replacement: 4 단계, 이미지 1/1
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Olympus Stylus 1010 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Olympus Stylus 1010 Motherboard Replacement: 6 단계, 이미지 1/3 Olympus Stylus 1010 Motherboard Replacement: 6 단계, 이미지 2/3 Olympus Stylus 1010 Motherboard Replacement: 6 단계, 이미지 3/3
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
  7. Olympus Stylus 1010 Motherboard Replacement: 7 단계, 이미지 1/3 Olympus Stylus 1010 Motherboard Replacement: 7 단계, 이미지 2/3 Olympus Stylus 1010 Motherboard Replacement: 7 단계, 이미지 3/3
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
  8. Olympus Stylus 1010 Motherboard Replacement, Lens: 8 단계, 이미지 1/2 Olympus Stylus 1010 Motherboard Replacement, Lens: 8 단계, 이미지 2/2
    • Still using the spudger, detach the three gold wire tape connectors from the inside of the camera.
  9. Olympus Stylus 1010 Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove the three screws from the inside of the camera using a #00 screwdriver.
  10. Olympus Stylus 1010 Motherboard Replacement: 10 단계, 이미지 1/2 Olympus Stylus 1010 Motherboard Replacement: 10 단계, 이미지 2/2
    • Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
  11. Olympus Stylus 1010 Motherboard Replacement, Motherboard: 11 단계, 이미지 1/1
    • Remove the two Phillips #00 screws on the right side of the camera.
  12. Olympus Stylus 1010 Motherboard Replacement: 12 단계, 이미지 1/1
    • Still using the spudger, detach the gold wire tape connectors from the motherboard.
  13. Olympus Stylus 1010 Motherboard Replacement: 13 단계, 이미지 1/1
    • Desolder the upper right and lower left wires to remove the motherboard.
  14. Olympus Stylus 1010 Motherboard Replacement: 14 단계, 이미지 1/2 Olympus Stylus 1010 Motherboard Replacement: 14 단계, 이미지 2/2
    • In order to remove the motherboard, grab each side of it and pull up using your thumb and forefinger.
결론
Max McIntyre
회원 가입일: 01/21/11
526 평판
안내서 4개 작성하였습니다
Cal Poly, Team 13-4, Forte Winter 2011 Cal Poly, Team 13-4, Forte Winter 2011 회원
CPSU-FORTE-W11S13G4
6 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 3,182
