이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the 2 screws on the bottom of the slider.
Remove both screws with a #00 Phillips screwdriver.
Gently pull on the bottom of the slider until it comes off the lower track.
There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Camera would not turn on nor lens extend. Took slider off per instructions and cleaned the switch and was able to rotate switch back and forth to turn camera on and off by hand. Reassembled slider and could turn camera on but not off. Disassembled again and find the rotating switch is permanently stuck in counter clockwise position and cannot be activated by hand. I do not want to force the switch because it did operate very easy. What can be the trouble?
rraff8300@sbcglobal.net
Excellent instructions for removing stylist 410 slider. Hope you can help with my prior stuck switch problem.
