소개
Use this guide to remove the battery in order to charge it, or do extensive work on the camera.
Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
If the battery is dead, charge it for 60-90 minutes.
거의 끝나갑니다!
Follow these instructions in reverse order to reassemble your device.
결론
