주요 콘텐츠로 건너뛰기
Disassembling Olympus Stylus 725 SW Front Panel
필요한 것
  1. Disassembling Olympus Stylus 725 SW Front Panel, Disassembling Olympus Stylus 725 SW Battery: 1 단계, 이미지 1/2 Disassembling Olympus Stylus 725 SW Front Panel, Disassembling Olympus Stylus 725 SW Battery: 1 단계, 이미지 2/2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Disassembling Olympus Stylus 725 SW Front Panel, Front Panel: 2 단계, 이미지 1/3 Disassembling Olympus Stylus 725 SW Front Panel, Front Panel: 2 단계, 이미지 2/3 Disassembling Olympus Stylus 725 SW Front Panel, Front Panel: 2 단계, 이미지 3/3
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
결론
Bobby Hodges
회원 가입일: 04/18/10
49 평판
안내서 6개 작성하였습니다
Cal Poly, Team 33-71, Johann Spring 2010 Cal Poly, Team 33-71, Johann Spring 2010 회원
CPSU-JOHANN-S10S33G71
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 3,236
