이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to remove the front panel to access the components inside.
필요한 것
Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
If the battery is dead, charge it for 60-90 minutes.
Remove the top screws using a 1.5 mm screwdriver.
Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
