주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This guide provides instructions for disassembling a broken LCD screen on the Olympus Stylus 725.
부품
지정된 부품이 없습니다.
  1. The battery is located on the bottom of the camera. Remove the battery by placing your thumb on the buttom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the buttom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • Charge the battery for 60-90 minutes if your battery is dead.
    • When installing a charged battery, align the battery appropriately, with the positive signs and negative signs lining up.
  2. Unscrew the 3mm long cover screws at the corners of the camera using a #00 Philips Screwdriver. Unscrew the 2mm long screws securing the sides of the camera which holds the back panel. Use the same screwdriver. Unscrew the 2mm long screws securing the sides of the camera which holds the back panel. Use the same screwdriver.
    • Unscrew the 3mm long cover screws at the corners of the camera using a #00 Philips Screwdriver.
    • Unscrew the 2mm long screws securing the sides of the camera which holds the back panel. Use the same screwdriver.
  3. Be careful when removing the back cover, you will need to detach the connecting ribbons Detach the ribbons using your thumb, sliding them out of their slots.
    • Be careful when removing the back cover, you will need to detach the connecting ribbons
    • Detach the ribbons using your thumb, sliding them out of their slots.
  4. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  5. Use a #00 Phillips head screwdriver to remove the screws in the back panel. After removing the back panel,  slide the ribbons off the computer chip to detach them. After removing the back panel,  slide the ribbons off the computer chip to detach them.
    • Use a #00 Phillips head screwdriver to remove the screws in the back panel.
    • After removing the back panel, slide the ribbons off the computer chip to detach them.
  6. Use tweezers to remove the loosened LCD screen. Be careful to not scratch the new LCD screen when replacing it.
    • Use tweezers to remove the loosened LCD screen.
    • Be careful to not scratch the new LCD screen when replacing it.
    • Carefully place the new screen in place of the old, making sure the label faces up.
    • Slide the ribbons back onto the computer chip.
    • Using the #00 Phillips head screwdriver from before, screw the screws in the back into the panel.
결론
Be sure to test the device by turning it on once the screen has been replaced. Make sure that the new screen works properly.
다른 한 분이 해당 안내서를 완성하였습니다.
Bobby Hodges
회원 가입일: 2010년 04월 18일
49 평판
안내서 6개 작성하였습니다
Cal Poly, Team 33-71, Johann Spring 2010 Cal Poly, Team 33-71, Johann Spring 2010 회원
CPSU-JOHANN-S10S33G71
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 7,662
