소개
This prerequisite guide provides instructions that need to be performed before beginning replacements on your Olympus Stylus Tough 6020.
필요한 것
Turn the camera so that you are facing the bottom of the camera.
Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
Using a spudger, pry off the plating on the bottom of the camera.
Turn the camera so that you are facing the top of the camera.
Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
Using a spudger, pry off the plating on the top of the camera.
Turn the camera so the LCD is facing upwards.
Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
Using a spudger, gently pry off the black "Olympus" face plate.
Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
Turn the device over so the front of the camera is facing you.
Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
Using a spudger, pry off the end casing.
Turn the camera so the blue face plate is visible.
Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
Using a spudger, gently pry off the blue face plate.
Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
다른 2명이 해당 안내서를 완성하였습니다.
