주요 콘텐츠로 건너뛰기
Disassembling Olympus Stylus Tough 6020 Prerequisite Guide
필요한 것
  1. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Battery: 1 단계, 이미지 1/1
    • Slide and push the battery casing to open it.
    • Push the battery to eject it.
  2. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: 2 단계, 이미지 1/3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: 2 단계, 이미지 2/3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: 2 단계, 이미지 3/3
    • Turn the camera so that you are facing the bottom of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
    • Using a spudger, pry off the plating on the bottom of the camera.
  3. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: 3 단계, 이미지 1/3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: 3 단계, 이미지 2/3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: 3 단계, 이미지 3/3
    • Turn the camera so that you are facing the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
  4. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Left Plating: 4 단계, 이미지 1/2 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Left Plating: 4 단계, 이미지 2/2
    • Turn the camera so the LCD is facing upwards.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
  5. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: 5 단계, 이미지 1/3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: 5 단계, 이미지 2/3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: 5 단계, 이미지 3/3
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
    • Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
    • Using a spudger, gently pry off the black "Olympus" face plate.
  6. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: 6 단계, 이미지 1/3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: 6 단계, 이미지 2/3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: 6 단계, 이미지 3/3
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
    • Turn the device over so the front of the camera is facing you.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
    • Using a spudger, pry off the end casing.
  7. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: 7 단계, 이미지 1/3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: 7 단계, 이미지 2/3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: 7 단계, 이미지 3/3
    • Turn the camera so the blue face plate is visible.
    • Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
    • Using a spudger, gently pry off the blue face plate.
  8. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Back Plate: 8 단계, 이미지 1/1
    • Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
  9. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: 9 단계, 이미지 1/3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: 9 단계, 이미지 2/3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: 9 단계, 이미지 3/3
    • Using a Phillips 00 screwdriver, unscrew the wide 3.5mm screw located in the middle of the camera.
    • Using a Phillips 00 screwdriver, unscrew the 9mm screw located at the top left corner of the camera.
    • Using a spudger, separate the black plate from the camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Taylor Carabin
회원 가입일: 04/15/15
259 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 24
전체 시간: 799
