소개
Follow these instructions to learn how to remove the Olympus Stylus Tough-8010 camera's casing.
필요한 것
Remove the front three screws (3.2mm) using a type T-6 head screwdriver.
Take off smaller front cover.
Carefully remove larger front cover.
이 단계에 사용된 도구:Tweezers$4.99
Remove four screws (9.4mm) on the front of the camera using a Phillips #000
Use the plastic opening tool to release the holding clip.
Using tweezers separate the plastic strips from their connectors located on the main circuit board by lifting the small, black flaps on the connectors and pulling on the ribbons.
다른 3명이 해당 안내서를 완성하였습니다.
